Connection Issue Between Router, DAC, and Nucleus (ref#911ARG)
Is Roon Server running?
· "Looking for your Roon Server"
· *Nucleus*
· *VPN* installed on RoonServer or Roon Remotes
Lan cabel from Router to DAC and Nucleus
What type of computer and operating system are you using for your Roon Server? What computer or phone/tablet is receiving the “Looking for your Roon Server” message? The more detailed information you provide will assist in identifying possible solutions.
Also, why do you have a VPN running on this computer? VPNs are not a supported configuration for Roon and may cause connection issues similar to what you are experiencing.
Hi svalbard7,
Thanks for writing in! I wanted to check in on your status and see if you were still having issues.
@Robert_F is correct in that the more details you can provide specifically around your connection issue, the better. I see you’re running a Nucleus for your Roon Server, are you able to access the webUI of the device?
Here’s more info:
