I am not a tech expert - but if ROCK is based on Linux and there is no drivers how can it than be approved by Roon?
Torben
PS: and it seems to be more problems with NUC12
Torben
Just because Intel maybe didnât yet contribute a driver for this NIC to the Linux kernel doesnât mean that the Linux kernel has no driver for it.
Intel has become quite good at contributing to Linux now that the IT world as we know it is unthinkable without Linux or other free Unix clones, but Linux was going strong for many, many years before most manufacturers even thought about starting to contribute. Until the 2000s most hardware drivers were reverse engineered by Linux hackers by playing with it until it was understood, or the manufacturer had published hardware specs but not a driver. And if we take all drivers into account that the kernel provides, Iâd bet itâs still a large majority. Thatâs why Linux keeps working on older hardware long after manufacturers abandoned it and donât provide driver updates anymore for, e.g., newer Windows versions
The NIC seems to have been supported by Ubuntu since 2021:
There is a saying ânever touch a running systemâ So maybe the time is not ready for a upgrade to NUC12
GrĂźĂe nach Berlin
Torben
Itâs always a tightrope. Get the latest and greatest hardware, expose yourself to the latest and greatest bugs and glitches. Previous generation hardware is kinder on the wallet as well.
I think in this case itâs likely just a bad match between a (more generic) driver and a controller that perhaps isnât Intelâs finest hour?
Ok guys, this afternoon I installed Windows10 on the NUC (it was a mess because I have to reformat the SSD in NTFS). Once installed, the NUC and my router had the green light blinking, but not able to connect to internet. Therefore I canât update the driver of the Ethernet port. I have a message that Windows does not detect any adapter⌠Haaaaa!!!
I will update this post once I have an update from Intel.
Thanks for your help
I am getting confused now, why are you suddenly installing Windows? Plus Geoff already mentioned that Windows installation does not have an ethernet driver for a similar NUC:
There is an option during Windows installation to add device drivers. You have to download it from Intel I guess and put in on some drive that you can attach. This is Windows 10 but 11 should be similar:
Or install the driver after the installation, like any other driver
If youâre going to the trouble of installing windows, you may try updating the NVM as I linked to above.
âŚalthough itâs possible the NVM only applies to windowsâŚ
I have contacted the Intel customer support for help. They want to troubleshoot the network issue using windows software. Probably to update the driver of the Ethernet port in Windows to see if the port is ok or not. I will do everything they want to fix the issue. In case everything goes bad they will send me a new one. In case if it works, I hope it will serve the Roon community in the future.
I see, makes sense I feel with you
Update.
I was troubleshooting the NUC with the help of Intel Customer Support.
What I have done:
A happy Roon user
Interesting. This sounds like it was a firmware update for the NIC? I wonder if that wouldnât have been possible without having to install Windows? (Dell machines, for instance, can update firmware from the BIOS via a USB stick without any need for Windows. Itâs quite common). Anyway, glad that it works, enjoy
Do you mean you installed Roon for Windows, or do you mean that you overwrote Windows by using the ROCK installer to set up Roon OS and Roon on your NUC?
I overwrite Windows 10
OK thanks. On another point, what do you see for Audio devices on the NUC in Roonâs Settings > Audio screen? Something like this?
Yes something like that
OK, then you are seeing the audio devices on your NUC12. Good.
Yes it works really fine.
Hello,
Are you seeing your HDMI ports?
HDA Intel PCH HDMI 1,2,3,4?
Also confirming you are running ROCK?
Yes Iâm running Rock. If you want to know if I see the hdmi port on setting > audio, no.
Happy you got it sorted!
