Consistent Poor Connection Error with Roon ARC while Outside Home (ref#89FCCQ)
I never had a problem with this until a few months ago. Now it seems like every time I leave my house I get the poor connection error when trying to use roon arc. Everything is fine when I go into arc settings on the desktop roon app. It says ready with the checkmark and I have opened the corresponding ports on my router. I have the mobile app set to bandwidth optimized. Also whenever I get this poor connection error I can pull up the same song/album on plexamp and it plays just fine. i’m not sure where else to look. I have reinstalled the app, cleared the storage on android. I even changed the port it was using and that seemed to work for about a day and now its right back to poor connection every single time.
Im using PFsense on a mini PC, my roon server is connected via ethernet to a dumb switch. No VLANs or anything
Hi @donfrenchiano,
Thank you for your post. Diagnostics from ARC indicate that the phone OS reports a strong cellular connection and that the phone has no issue pinging RoonServer from a cellular connection. There doesn’t appear to be a connection issue but a problem with RoonServer and ARC’s authentication process - the keypair for ARC doesn’t match that of RoonServer, rendering the session layer invalid.
In other words, ARC can reach RoonServer, but it’s not allowed to connect. The short-term solution is to reinstall the app and resync with your server, requiring you to redownload local library items to ARC that you’ve saved. Long-term, I’d make sure RoonServer.exe and other Roon processes are safelisted in PFsense, in case authentications are getting caught by the stateful firewall.
Please verify that you’ve installed the latest ARC build, as the most recent release (yesterday) contains overhauls to server connectivity that improve this condition.
I have already uninstalled/reinstalled the app on my phone. I have the newest version. I am running roon server on linux. Whenever I reinstalled the app or clear the data half the time it can’t connect to the server to re-sync it. are there other ports I need to open on my firewall or something? This used to work fine.
Do you have anymore information on this? I have tried all kinds of stuff. I have uninstalled/re-installed the app. I have changed port numbers, I have enable upnp which doesn’t seem to even try to open up a port when using that. I have tried tailscale which didn’t work.
Hi @donfrenchiano,
Thank you for your post. The team is investigating this issue and the associated diagnostics.
If you’re willing to give one more uninstall/reinstall of ARC a try, please first perform a database refresh to reset the RoonServer’s authentication credentials.
  • Exit out of Roon + RoonServer (from taskbar area)
  • Find the folder that says “Roon Server”
  • Rename the “RoonServer” folder to “RoonServer_old”
  • Reinstall the RoonServer App from our Downloads Page and open Roon to automatically generate a new RoonServer.
  • Uninstall/reinstall ARC.
We’ll follow up once we have more notes from development. This is unrelated to port forwarding or Tailscale and a unique connectivity condition between server/ARC (possibly a bug). Thank you for your patience!
I just tried this and I even tried to connect to ARC without restoring my DB so it was a fresh roon server install and still can’t connect.
Ok So i figured out a little more. If i re-install the app or wipe the data and go to login to arc it just spins and spins trying to connect to my server. If i go into the Roon ARC section on the desktop app and hit the refresh button to retest the port connectivity, Roon ARC on my phone immediately connects to my server and can do the sync. But then after a while I get the poor connection issues. It’s like something isnt leaving the connection open. Also this is on a manual port forward not a upnp.
Thanks for the update @donfrenchiano!
Did you try using UPnP? If that also caused you issues, perhaps testing out Tailscale may be a more reliable answer for your connection. Here’s more info on that:
Certainly, let us know your thoughts! :+1:
I mentioned this earlier. I have already tried upnp and tailscale and it didn’t work. Idk if it’s a coincidence and it will crap out again later but I enabled nat reflection on offense and was able to sync the library after a while and was able to play music all the way home from work and it is still working.
Hi @donfrenchiano,
It’s great to read it’s been working so far. We’ll keep this thread open for now in case the problem returns.
Well it didnt seem to work. I got the poor connection error again this morning .
Hi @donfrenchiano,
Thanks for letting us know. Based on the log traces that we found we think this is an issue that we are currently investigating. I’ve added your case to the ticket so you will be notified about any developments. I cannot give you an exact timeline on next steps but we will keep you in the loop. Thank you for your continued patience!
Hey @donfrenchiano,
Our Arc development team is still investigating the issue you posted about, but we’ve noticed that since then your subscription is no longer active.
Would you have any interest in continuing to troubleshoot if we get you set up with a trial subscription in the meantime?
Let me know! :folded_hands:
Hi @donfrenchiano,
It’s been a while since we’ve checked in with you. This thread will auto-close soon without a response from you. Let us know if you would like to continue troubleshooting.
