Hey folks,
So i got the project S2 to use as a roon endpoint/headphone amp, connected to my computer through USB.
It worked like a charm for 3/4 months, Now im facing a strange issue i reinstalled the drivers but still the same : the box emits a constant white noise through the headphone amp (i never used the pre-amp RCAs to verify) and when i play through roon it just stuters/buffers plus the white noise (literally unusable).
I have tried it with another Laptop but as i just plugged it in got recognized by the laptop the noise again started on the headphones.
I haven’t changed the usb cable to be fair, but i don’t really think anything happened to the cable that could damage it (ugreen usb B to usb A cable).
When i set it to ASIO it still DOESN’T work with Roon, but occasionally works fine with Tidal or foobar, but no MQA/Sample rate indication it shows 48khz only no matter what the file played, and again randomly works.
Roon core is on the same desktop machine (poweful i7 quad core with 32gb ram and endless storage space).
Yeah i tried another usb port on the computer, same story.
Anyone experienced the same issue ?
