What’s happening? · Something else
How can we help? · None of the above
Other options · Other
Describe the issue Roon bit depth 24bit to 16bit
Describe your network setup Roon server on MacBook pro to Wiim Pro+ via Roon Ready setting to amplifier via digital coaxial cable. No active MUSE settings.
Have you adapted the Wiim‘s configuration?
CrystalGipsy
(Resisting the flow!)
November 4, 2024, 7:39am
3
Check your settings here in Wiim app isn’t set to 44.1 and fixed rate. If ok and still happening then reboot your server someone else has same issue with the Ultra recently.
noris
November 4, 2024, 9:49pm
4
Hi @Travis_Finch ,
I would also suggest checking Device Setup → Max Sample Rate to ensure you haven’t accidentally changed it. Let us know if this helps!
system
(system)
Closed
November 18, 2024, 9:49pm
5
