ROCK Version 1.0 (build 227) stable
ROON Version 1.7 (build 710) stable
Fixed network (ethernet) through TP-Link switch.
Topping D90 DAC over USB
Ropieee on Rpi4, version 3.020 stable
I use convolution filters generated from AudioLense via roon’s convolution filter for room correction.
Prior to the upgrade to Roon 1.7 build 710 all was fine. However after the upgrade, playing music with sample rate >44.1 results in silence. If I go into DSP settings and turn off the convolution filter, music starts again. I have tested this with local files as well as QoBuz streamed music.
44.1k/16bit material plays fine. 44.1k/24bit also fine.
While playing a “silent” track I get the following path:
Things I have tried:
Disable volume levelling. No change
Generating 32 bit filters rather than 64 bit. No change
Having a smaller set of filters (removing 192k rate). No change.
The DAC shows the correct sample rate for the material being played (e.g. 96k), but no signal.
I am happy to supply the zip file of the filters if you’ll let me know where to put them.
Thanks in advance
Paul.
