16 Port 1 Gb Switch
Cat 6 Ethernet cabling
Asus Wireless Router
Wired to Bluesound Node 2021
Bluesound Node 2021 connected over USB to Schiit Bifrost 2 DAC connected analog to Preamp
3962
When playing through Roon, I continually get random pops and clicks while listening to my library or Qobuz music. This does not happen when I play through the Bluesound application. Also, I was able to eliminate the crackles and pops by disconnecting the USB cable and swapping for digital RCA cable. No pops or crackles. My preference, though, is USB. It would seem Roon doesn’t work with the USB cable connected.
Thanks for the link. You were correct, I owe you an apology. It only happens with USB. When I switch over to a digital coax cable, the pops and the clicks disappear.
