I’m curious to have some qualified suggestions and evaluation about the OpticalRendu or any other similar stuff. Maybe my doubt is trivial, if so, I apologize in advance.
I have a quite “old” set-up, minimac, usb connection to DAC, no ethernet.
Regardless the additional cost, from listening point of view, is it worth?
May I reduce the change only to power improvement of the source?
I don’t know, for instance, the linear power supply of Minimac instead of what describe above.
@Sante_Roon I am currently using the setup you are describing. A few things that motivated me to this setup.
My Roon core is in a different room, I don’t have space to put a noisy machine in the same room (fans etc)
The opticalRendu does separate a direct USB connection from the electrical noise of the computer as well.
The optical cable additionally gives galvanic isolation from the ethernet network.
A linear power supply on the opticalRendu further reduces the noise floor.
The opticalRendu can receive higher bitrates 32bit/768KHz and DSD512, much higher than my Mac could output. I think my Mac maxes out at 32bit/96KHz
All of this does add complexity and cost to the system. It is an incremental improvement in the overall sound quality.
I do this in my main listening room and not my desktop or bedroom listening area where the equipment may not resolve as much. Personally I do feel that the sound is better, it is a very personal choice. I do enjoy tinkering with my system. For me it is part of the journey.
Except that it is not. Does the 10Gtek have Four (4) high-quality ultra low noise linear regulators?
Does it use a fixed frequency high-quality ultra low jitter FEMTO oscillator?
