Updated my Devialet Expert two days ago. Play ROON through the Devialet now plagued with dropouts. When I go into ROON setup the ‘Roon Ready’ audio option appears and disappears every 10 seconds or so.
ROON is installed on a dedicated NUC. All connections are wired ethernet
I had the same issue, and it was resolved with unplug the Devialet power chord and plug after 10 seconds
OK, unplugged and rebooted. It’s been 30 minutes now and no problems so far. Thanks, it looks like you’ve fixed it for me!
