synology diskstation Model: DS220+, x86_64,6 GB RAM, DSM Version: 7.0.1 (Update 2)
Ethernet
Roon Bridge on Raspberry Pi 4b, raspi os 64 bit bullseye
Device: ALSA Loopback , sampling rate 96k
When raspberry pi is powered cycled, cannot play music on device until I enter roon audio setup then enter edit device.
Device is ALSA single frequency of 96k, roon tries to send audio at audio file native sampling rate.
sample log
02/13 10:20:48 Trace: [tidal/http] GET https://api.tidal.com/v1/tracks/77702187/playbackinfopostpaywall?countryCode=CA&audioquality=HI_RES&assetpresentation=FULL&playbackmode=STREAM => Success
02/13 10:20:48 Debug: [easyhttp] [15899] POST to https://browse.roonlabs.net/1/works/trackCounts?c=tidal-ca returned after 182 ms, status code: 200
02/13 10:20:48 Debug: FTMSI-B ti/2CC3E640 download status: FirstBlockRetrieved accessTimeout:False openFiles:2 prev:(FileLengthRetrieved,False,2)
02/13 10:20:48 Debug: GET /image/zszbaaaa.512.jpg
02/13 10:20:48 Info: [Living Room Stereo] [zoneplayer] Open Result (Playing):Result[Status=Success]
02/13 10:20:48 Info: [Living Room Stereo] [zoneplayer] Starting playback
02/13 10:20:48 Trace: [Living Room Stereo] [zoneplayer/raat] StartStream Sooloos.Broker.Transport.RaatZonePlayer+Endpoint: StreamFormat(channels=2, bitspersample=16, samplerate=44100, isdts=False) => StreamFormat(channels=2, bitspersample=32, samplerate=44100, isdts=False) streamid=1656384390
02/13 10:20:48 Trace: [Loopback PCM] [raatclient] SENT [13]{"request":"setup","format":{"sample_type":"pcm","sample_rate":44100,"bits_per_sample":32,"channels":2,"sample_subtype":"none"}}
02/13 10:20:48 Info: [zone Living Room Stereo] OnPlayFeedback Playing
02/13 10:20:48 Trace: [Living Room Stereo] [HighQuality, 16/44 TIDAL FLAC => 32/44] [100% buf] [PLAYING @ 0:00] You Don't Know Me - Patricia Barber / Michael Arnopol / Adam Cruz / Eddy Arnold / Cindy Walker
02/13 10:20:48 Trace: [Loopback PCM] [raatclient] GOT [13] {"message":"RAAT__OUTPUT_PLUGIN_STATUS_FORMAT_NOT_SUPPORTED","status":"UnexpectedError"}
02/13 10:20:48 Warn: [Living Room Stereo] [zoneplayer/raat] failed to setup any endpoints..giving up
02/13 10:20:48 Info: [audio/env] [zoneplayer -> stream] All streams were disposed
02/13 10:20:48 Info: [audio/env] [zoneplayer -> stream -> endpoint] All streams were disposed
02/13 10:20:48 Info: sleep 0ms after flush
