Quiet PC UltraNUC Pro 7 Fanless / ROCK Version 1.0 (build 174) stable
not relevant
Pro-ject DAC Box S2+, dircet connect to ROON Core via USB
Rhe ROON Core does not identify my DAC it is listed as “unintentified device” in Device Setup. The Conmnection is named " DAC Box S2+ USB". When I try to manually identify the device, my DAC is not listed among the Pro-ject devices. Please check with Pro-ject to includ emy device.
We’re working with our partners to get device icons for all of our Roon Tested DACs into the app. I can’t speak to when we will have an icon for the Pro-Ject Pre Box S2 Digital, but stay tuned as new icons are being added all the time.
Hi @dylan
Thanks for your response. If the “Device identification” is only about the icon, then I don’t really care. But if you are maintaining a list of acceptable parameter values for the device, this would be nice to have.
Also I don’t talk about the “pre box” but about the “dac box” which is slightly different (no MQA support, no DSD512)
Kind regards, Martin
