Box Orange WIFI Audio Devices (Specify what device you’re using and its connection type - USB/HDMI/etc.)
MOON 390
Variable volume from Device doesn’t work anymore. Even if flagged as “Use device control”, main screen shows “fixed volume”.
Thanks for your assistance
Rather than start a new post i thought i’d add to this post, as i’m also having volume control issues.
Previously i could control the volume using ‘Device Volume’ setting. With this setting now, volume does not change whilst using the volume bar adjuster…as if its using fixed volume.(but not displayed)
My Roon Settings on Windows 10 laptop.
Meridian Explorer via USB to laptop.
Laptop is wired to network switch.
Sky Q router being used.
