Hello,
I’m sure I’m missing something obvious, so thanks in advance for your patience and help!
I’ve got the latest DietPi, Roon Bridge, and Shairport installed on my RPi 3. Works perfectly as a Roon endpoint. No issues. Bit perfect, high-data rate, perfect.
Airplay, however is not working. The RPi shows up as an Airplay device, and I can select if from my Mac, or Apple TV as an audio output, and it even says the music is playing, but no sound comes out my speakers… The volume is fine on the preamp, it’s fine in ALSA.
Using USB-DAC as the ALSA output with the preamp’s USB input selected.
Thanks in advance for any help!
Best,
—Pedro
