Distinguishing between external networking issue and local networking issues in error message
I run my network with a server connected via wired network, and some of my endpoints are wireless, including a Pi Zero with USB-C 3.5mm adapter to a mono speaker.
Today while I was playing to the PiZero, the remote kept timing out and complained about “slow data/slow music” (sorry can’t remember the exact details).
At first I thought it’s my Qobuz external networking acting up, but restarting Roon, logout/login Qobuz didn’t help and all my other devices seems to be working as intended without stutter.
This is when I looked at the server log and found that it’s the server having a hard time syncing the clock to the PiZero. I think Roon should improve the messaging and pinpoint the exact issue because according to the logs, the server knows exactly what’s going on. (endpoint X is having trouble syncing with the server). Having a vague error will throw a lot of people off (you can definitely tell from the long list of complaints that went nowhere on this site)
After rebooting my home router, everything was back to normal.
@leafy seems like a reasonable request for the Roon product team. Suggest posting to Feature Suggestions forum sub-category. Here’s a benefit of doing so:
We will periodically mark features with brackets in the title explaining if it is done or not on the roadmap.
This category has voting enabled. This means that at the top of a thread there is now a Vote button. Tapping this adds one of your limited votes to the topic. Tapping again will give you the option to remove your vote.
You can check on your active votes via your profile page under activity.
Thanks @Dadoo , this suggestion is great and I’ve moved it.
