MACbook Pro Monterey 12.5.1
My path is the following:
Qobuz->internet->My Freebox Router->MacbookPro with Roon App → WIFI → My Freebox Router->Ethernet->My Devialet Phantom
Devialet Phantom I connected to the router (Freebox) through Ethernet
97000
Does Devialet Phantom I with ethernet connection works with Roon (with WIFi disconnected on my Phantoms) with Roon App ?
Is only Airplay supported ?
AceRimmer
(Smoke me a kipper, I'll be back for breakfast!)
August 19, 2022, 3:13pm
2
Yes absolutely and extremely well.
It should show up as Roon Ready device in settings: audio.
Unfortunately it does not show in audio settings . How to make it appear ?
bearFNF
(bearFNF)
August 19, 2022, 3:53pm
5
I would check your firewall settings and see if it is preventing you from seeing the Phantoms.
Try turning firewall off for a bit and see what happens. You might need to add Roon and RAAT server as exceptions in your firewall.
Firewall settings were the problem : need to authorize inout connections. it works now . Thanks a lot for your help.
system
(system)
Closed
August 21, 2022, 6:25am
8
