· I have a Grimm Audio MU1 and I stream using Qobuz. The MU1 can be attached to the router directly as stated by Grimm. I also have an audiophile switch. Both ways give the same results in respect to getting dropouts with HiRez material. I managed to perceive HiRez tracks that I transferred onto the internal hard disk drive. Playing these tracks also gives dropouts. As soon as I stream tracks with 44,1 kHz-16 bit chances that I'm plagued by these dropouts reach zero. Also 44-16 tracks from internal disk gives no problems. Most of the times when I turn on the MU1 it takes some time before the first dropouts appear, say one or two hours. I switched the ethernet cables, I contacted Grimm. They updated a cable in the machine and some mysterious particle (crystal something, they would not specify) was replaced. The dropout issue was over. If the dropouts would occur again, it should be caused by the network, they said. And after a few months the phenomenon started again. KPN (My supplyer of internet) checked and everthing was normal. So I got in contact with a forum of users on which KPN also has a technical guy surveying. He helped me change two settings in my router/modem. It did not help. So... what's next? One person reading my posts is helping me out, by trying my MU1 at his place. He'll keep it at his home for at least three weeks, so that will check if the network is to blame or not. In about a month I will have it back... But I still write to the technicians of Roon. Maybe they will come up with some useful information. Thanks for reading... Maestro57
The dropouts we’ve identified in your logs are a result of an upstream content delivery network problem with the Qobuz API. Our team has escalated the issue to Qobuz and this issue can sometimes manifest even outside Roon with Qobuz content.
Here is the tracking thread where we will be providing updates as we receive them from the Qobuz team:
In the meantime, we will share your report with Qobuz so they are aware another user is affected. Thank you!
@Eric_Besemer, the above issue not does affect Tidal content, so it’s quite likely you’re facing an entirely separate problem (and likely more immediately resolvable). Please reach out here in a dedicated tech support request and we’ll promptly follow up.
Hello Connor,
Thank you for responding on my thread. So it is up to Qobuz to clean up this drop-out-mess. I hope you ‘shouted’ loud enough to wake up the responsible guys at Qobuz’s.
The dropouts hardly appear when an album is available as 44 kHz-16 bit. As soon as I pick the same album or track with for instance 64 kHz-24 bit and higher the dropouts tend to pop up.
Anyway… I will have to take a peek now and then at some other thread…This one": ‘Roon won’t play track from Qobuz, gets stuck on progress bar’… This title does not apply the problem I meet, but anyway, I will look now and then.
If I did not have bought myself an more than one year presriction I would have gone back to Tidal. (I liked the sound quality of Qobuz a little bit more.)
Thanks for the update. As you noted, the dropouts are much less common with 44 kHz, 16 bit material, and tend to show up more often with higher resolution Qobuz content.
Please check back on the thread from time to time for updates. We will keep things moving on our side.
I’ll chime in on the matter.The MU1from this thread resides at my place for a couple of weeks. I’m located in a different province in The Netherlands, and haven’t had much drop-outs in the 20 something listening hours. 1 with regular 44/16 material and around 3 with higher bitrates. Within the next days i will load up some Qobuz files with know errors on the home base from the MU1
In the meantime there is a sort off progress. A not completely seated SATA cable between the PC motherboard and the 2TB SATA SSD containing the audio data and some Roon server related stuff like backup files and logs may have caused some intermittent I/O faults. Especially by high bitrates.According to the support staff at Grimm Audio that could affect the streaming audio from Qobuz as well. Due to the differences between Johan’s setup and mine it is also possible that a impedance mismatch from the AES/EBU cable he uses at home might also have something to do with it. I use the SPDif output.
