I am using a NUC Intel as core.
When conected to my DAC WEISS USB with capacity for DSD 128, I see that Roon instead of sending native DSD to the DAC it convert to 354 Khz, altough I set native DSD in the configuration.
WHY?
WHY?
Difficult to say without seeing screenshots of your Audio settings for that zone and the signal path.
In order for Roon’s @support team to better assist you, please provide a brief description of your current setup using this link as a guide.
Make sure to describe your network configuration/topology, including any networking hardware currently in use, so they can have a clear understanding of how your devices are communicating.
State the OS of your Roon Core. Windows or ROCK? And provide everything the above posts mentioned.
Disable DSP Engine. Disable volume leveling. Set DSD strategy to DoP.
Thanks for help. Finally I got to fix with native DSD not conversion to PCM. Th error was a wrong setup of my DAC DSD capability which oblige the conversion.
Then subject closed
