Ethernet utilising Netgear switches
Allo Digione feeding an Arcam irDAC-II via coax
Hi there,
I understand my DAC is capable of doing DSD64 over DOP and I can set it up that way in Roon however when I press play the file does play and I can track the path, but there is no sound from the speakers. Is this something you can help with?
Thanks @wklie - that makes sense although I will need to move to another room to try as my NUC is squirrelled away in a cupboard, but I could switch streamers to test.
Ultimately I wanted to give DSD upsampling to this DAC a go, but not a deal breaker.
From the irDAC-II manual. It shows DSD128 only over USB connected to a Windows PC with the driver loaded. I would email Arcam tech and ask them how to play DSD to the DAC.
