TEXT GOES HERE
Mark Levinson 585 - USB connection
Hi, I’ve been using Roon for many years and I never had a problem since I decided to change my SSD on my MacBook Pro Retina. Since that Roon and other programs aren’t able to recognise my device, a Mark Levinson 585, as a DSD capable dac. I tought was a problem of my computer so I tried to use Roon on another Macintosh but unfortunately I noticed the same problem. I contacted Mark Levinson support and they told me that can’t be a DAC problem (it works fine with PCM files) but something else and invited me to contact you to solve the problem. Can you help me? Before my SSD substitution I was able to play DSD via DoP using my Mark Levinson device.
Hi @dylan
yes I’m seeing this on all applications (Roon, Audirvana, Hq Player) installed on my MacBook Pro Retina and also my MacBook Air Retina. I can’t verify if I have the same problem using antother operating system like Windows for example, but on every MacOS Catalina I’m having trouble reproducing DSD via DoP. If I select this option all I hear from my speakers it’s a terrible noise, not music at all.
A little update, I tried to change USB cable with no improvement. After that I decided to delete and install again CmediaUSBDSD driver from Mark Levinson website but when I selected uninstall I had this answer: “CmediaUSBDSD driver is not installed”. I think at this point that there is a problem between MacOS and that driver. Is there the possibility to see where this kind of driver is installed on the operating system? Thank you.
