Well. Yes and no. All filters for all sampling frequencies are 524k taps. And all work well for PCM input, regardless fs and with processing speed usually around 10-15x.
The converted DSD to PCM uses almost 4x the number of taps. Roon must generate them from the original ones. Clearly for DSD native input this makes sense. Is there a setting in Roon allowing to use the original filters with a DSD to PCM converted signal?
Experiment 1: Switching SRC in DSP on and define custom target for all DSD of 192kHz: No effect. Roon does still create weired convolution filters. Switching SRC on/ off and/ or varying the custom target Fs doesnât solve the problem.
Experiment 2: Limit the max PCM frequency in the device settings to 192kHz: That does solve the problem (see screenshot). And this does not need SRC to be enabled. It seems to trigger an automated conversion.
[image]
What this doesnât solve: The weird filter tab length. This only becomes the correct 524k taps, when the maximum Fs is 96kHz or lower.
We apologize for the lack of a timely response and thank you for the additional information.
If Roon detects that you have not included in your convolution filter zip file a filter that matches the sample rate of the content it will automatically resample the filter to match the content.
For example:
Media: 96 kHz
Filters: 44.1kHz @ 5000 taps, 48kHz @ 5000 taps
Result: Roon will resample the 48kHz filter to 96kHz, doubling the number of taps to 10000.
What sample rates have you generated filters for and included in your zip file?
thanks for your reply. I have already read in the documentation that Roon does extrapolate. I have got all CFGs and WAVs for 44/88/96/176/192/352/384k.
The WAV files have got the correct Fs. However, re-evaluating the the CFG files, I have had an error: It should have read 352800 (not 352000). When reading the ZIP, Roon does seem to ignore the real Fs of the WAV when the Fs specified in the header of the CFG isnât correct.
