I can play DSD256 and DSD512, no problem, with Poly sinc guass long, ASDMEC7v3 and I can play 44.1 source material at DSD1024 w/ poly sinc guass short, AHM7EC8B (or 4B).
However, anytime the source moves families to 48 or 96 during DSD1024, I get audio dropouts every 10-15 seconds during play (even with processing speed of 3.18x).
In the matrix, I have DAC correction ON, as well as Accurate Sound Headphone Convolution Filters.
Wanted to paste my Embedded settings to see if there were any glaring issues that could trigger the dropouts. Would sincerely appreciate any feedback/help
Updated buffer with not much/if any change. But you are right, while the processing speed stays constant, the output buffer fill level drains … it starts around 85-90%, drains all the way down, then replenishes, keeping that cycle throughout the track
So it is likely running out of processing power, or alternatively there’s a data transfer issue to the NAA.
You are sure ethernet link to the NAA is not running at 100 Mbps instead of 1 Gbps link speed? Because for example this is precisely kind of issue people have when they are using etherRegen or similar.
With AHM there should be plenty of CPU/GPU power headroom with your system. So I would primarily suspect transfer issue with the NAA.
Depending on how feasible it is from practical point view, you could try directly connecting the DAC through USB to the HQPlayer server.
