DSP Engine: Convolution where you can download filters ???
A room EQ filter must be individually created for the room it is designed for. You can do this yourself using a USB microphone with appropriate software like Room EQ Wizard (see the discussion in this thread )or you can arrange for someone local to do it for you. There are also now a number of remote EQ shops who will turn your measurements into filters.
