Torben_Rick
(Torben - A Dane living in Hamburg - Roon Lifer)
June 8, 2023, 2:59am
1
I just installed DSP filter with crosstalk and it works fine in my setup.
The only problem is with DSP128 files (DSP64 is fine). Processing speed of DSD128 files dropped to <1x (see below)
I use an Intel NUC Comet Lake i7-10710U.
Is there anything that can be done to get it over 1 gain?
Torben
Marian
(I stand with Ukraine)
June 8, 2023, 4:49am
2
Disabling “native” DSD processing will save you a lot of computing power; you won’t lose anything in terms of quality.
Marin_Weigel
(Bram Stoker's Cappuccino)
June 8, 2023, 5:28am
3
Or get a silent PC with a potent desktop CPU, if you need to scratch that DSD itch - you didn’t cheap out on the rest of your system, did you?
Marian
June 8, 2023, 5:42am
4
DSD + DSP is not DSD anymore. You’d be scratching a prosthetic limb.
Marin_Weigel
June 8, 2023, 5:43am
5
… almost spilled my coffee, laughing
Rugby
(aka Daniel or Big Dan)
June 8, 2023, 5:46am
6
Move from a mobile/laptop CPU to a Desktop CPU would be my first suggestion.
Torben_Rick
June 8, 2023, 5:52am
7
THX @Rugby - If there is no easy fix than I will just dump the 3 DSD128 recordings that I have. DSD is not that important to me that I will buy a new desktop CPU. I am happy with my cirrus7 nimbini v3.
One last Q: Would a NUC 12 or NUC 13 (i7) have enough power?
THX
Torben
Marian
June 8, 2023, 5:58am
8
You don’t need to dump them, just disable native DSD processing.
Marin_Weigel
9
Edited post to delete content, since I realized that I probably got up on the wrong foot today, sorry for that
Marian
June 8, 2023, 3:35pm
11
They sure do, but the scratching is just placebo.
mitr
(Kal Rubinson)
June 8, 2023, 6:53pm
12
Yup. Great analog for the high-end audio tweakers.
system
(system)
Closed
June 10, 2023, 6:54am
13
