DSP per track and output device
Many tracks would need some correction as the mastering has done something to the compatibility to your set-up…ahummm :slight_smile:
So in the ideal world I would love to have the option to choose a DSP setting per track. And even depending on the set (=connected renderer).
As an example: EWF’s All 'n All album or Donald Fagen’s The Nightly lack bass so I would like to add this standard to these albums. In the latter album the last track has slightly more bottom that the other tracks, hence setting per track.
Ideally you should be able to select ‘individual DSP mode’ per track, per album and per device. This way you can play your music collection in the best optimized way without touching anything.
