I STILL have the same issue, embarrasing…
I’ve split your post out since you appear to have posted in a very old thread.
Can you please clarify what the issue is you’re seeing? What is your setup like?
The setup is Roon Bridge on a Restek DAC no problem so far.
Auralic Aries which shows always DSP Volume 0.0 and therefore the signal path turns green.
This problem was reported before but wasnt resolved so far.
That’s why I asked if it woumd be possible to disable DSP for one device or globally (as Change request for the future :-))
Best regards,
Armin
can be closed since i disabled volume control in the Aries WebGUI
