Issue device is a pioneer cinema receiver and roon rock install on an i5 motherboard, 8 gigs ram
50k
Its most odd. I am trying to sort out a solution for the kitchen so have speakers there and am able to use a zone out on the pioneer to power them. The pioneer has a USB input and DAC and sure enough when I hook the pc running rock to it, it shows up fine in roon and can be selected.
Music plays from the device. But behinf the music is like a flutters clicking distortion sound. It gets louder with the volume and remains on when there is no music.
but only if I have DSP volume enables (getting to the volume control on the pioneer is a pain).
If I set it to fixed or device volume then its perfect.
I have only seen this issue here now, never before and wondered if there is anything to try?
I cannot find anyway to access usb dac functions. I think it is what it is, but cannot imagine what I would change to stop this behaviour. I will try turning off MQA
