Can’t add to library though as every time Ii do it says album deleted.
Hey @Mark_Ranson
We’re sorry to hear that you’re having issues adding music to your Roon library.
Are you trying to add this album from Qobuz or TIDAL?
Has this resolved for you or is it still giving you issues?
If the problem persists please restart your remote or Core and then try to add it again.
If that doesn’t work you can always add it in either TIDAL or Qobuz and it will populate to your Roon library.
Please let us know if this helps.
The next day I started Roon and it was in the library. Seems it was just a glitch.
Thanks for replying.
