Hi @spockfish
Just changed my Pi 2 for a PI 3 B. I would like to enable wifi but it does not show on the netwotk page. Your help would be greatly appreciated.
Hi @spockfish
Hmmm… your device is not recognized as Pi 3 B.
Are you familiair with SSH? We can then check a few things. The model is being identified by it’s CPU identifier, and what might be the case is that your device is from a new revision and because of that not recognized by RoPieee.
Hi Harry @spockfish
I can ssh in. Let me know the user and pass and what to look for. It was a brand new PI 3 so probably new revision.
it’s specifically about the CPU revision. And they are constantly being updated.
So, login with user: root and passwd: root and run the following command:
cat /proc/cpuinfo | grep ‘Revision’ | awk ‘{print $3}’
Hi Harry @spockfish
It returned a52082. Does that sound right?
Wow. What I suspected, this one is not in the list.
So this is 3 B+?
No, it’s just a regular ‘3 B’. I looked it up.
Hi Harry @spockfish
Do you think you will be able to add this version of PI in the near future?
Yes, patch is already in. I expect to release within a week or 2.
Thanks Harry @spockfish
Version 110 has my pi3 now running on wifi and very stable.
I have another pi2 with an attached screen and allo digione. I can’t seem to get it to upgrade. I have rebooted it and waited a couple hours but it is still at version 100. Is there a way to force an update?
Can you send me feedback? Then I can have a look why it isn’t updating…
Hi Harry @spockfish
Here is the code e77f0b8921769cfc
ok. there’s a corrupted package in the way.
Same issue here @spockfish ,stuck on 100. Feedback c3f73bdf1873bc68 … I’m familiar with SSH.
He @Wakajazz,
There seems to be something wrong with the update timer configuration.
Would be great if you can show me that info.
Here we go:
Login with ssh, username ‘root’ and password ‘root’
run the following command to get me the info I want:
cat /etc/systemd/system/ropieee-update.timer.d/ropieee-update-override.conf
And then, while your at it, update with:
/opt/RoPieee/sbin/run-updates
Thanks,
Hi @spockfish
I am familiar with SSH
hi @Progisus,
The login with username ‘root’ and password ‘root’ and run the following:
rm -rf /var/lib/pacman/local/mesa-18.0.2-1
Thanks,
Thanks @spockfish
That fixed it!!
Both commands ran @spockfish, update to 110 successful.
Have you by any chance the output of the first command for me?
