New modem/router Motorola mg7700
Spectrum cable speed 100
TEXT GOES HERE
Roon point (2) bluesound & Cary dms500 WiFi all
TEXT GOES HERE
All Roon points r recognized by WiFi and operate fine. No recognition when Ethernet is hard wired. Problem started a couple of weeks ago about three days after update from Roon on the old modem, new modem did not fix this. The WiFi is working correctly and all devices r seen by Roon on WiFi.
TEXT GOES HERE
Welcome to the forum and apologies for the delay in getting back to you here, we’re getting back to everyone as quickly as we can following our 1.8 release.
Do the devices show up at all under Roon Settings → Audio, possibly via other sources like Airplay? If so, does that work as expected?
Have you made any custom configuration on the Modem? Do you have the Ethernet network separated from the WiFi? I would check to ensure there is only one router in your setup, sometimes ISP modems have a built-in router and this can cause two networks to be accidentally set up.
