I have my Router, NAS and NUC all situated together on a shelf. I would like an ethernet cable to my NUC but I have no spare ports on the Router or NAS.
Do I require some sort of splitter for the NUC?
Hi,
You need a simple unmanaged ethernet switch, they are typically available with 8 or more ports.
Connect the router to the switch and then the other devices to the switch.
As ISB supplied routers tend to be a jack of all trades, I prefer to have only the switch connected to it.
Thankyou…
There’s endless possible choices but you won’t go far wrong with something like this
NETGEAR GS105UK 5-Port Gigabit Unmanaged Ethernet Switch.
Yup - I have a couple of those Netgear switches in my network. The key thing is that the switch should be “unmanaged”- having “managed” switches can lead to problems…
