Excessive battery usage with Roon ARC in offline mode on iPhone 18 Pro (ref#9EMQJQ)
· Excessive battery usage with Roon ARC (1.85.439) in off-line mode on iPhone 18 Pro iOS version 27.2. Phone quickly becomes hot to the touch and 25% of the battery is consumed in 23 minutes.
· N/A this is Roon ARC in off-line mode
More info on this.
I had been in offline mode for over 1 month.
I went back on-line reconnecting to my Roon server, went off-line again and am not seeing the excessive battery usage or the over heating.
Hi @Inner_ear,
Thanks for the report, and for letting us know the problem went away after you reconnected.
Your Roon Server logs show no contact from ARC while the drain was happening. That means the battery use came from ARC on the phone itself, not from anything the server was doing. To find the cause, we’ll need a few more details if it happens again:
  1. Phone setup. Was the iPhone 18 Pro restored from a backup or transferred from an older phone? Roughly when? And is ARC installed on any other devices?
  2. Roon app. Do you also have the Roon app installed on the iPhone, and was it running in the background at the time?
Thanks for your patience while we look into this.
The problem has not recurred. For your information I offer the following:
Phone setup.
Was the iPhone 18 Pro restored from a backup or transferred from an older phone? Transferred from an iPhone 16 Pro.
Roughly when? 9/18/26
And is ARC installed on any other devices? Yes, an old iPad that has not been used for several months and is not powered on.
Roon app.
Do you also have the Roon app installed on the iPhone, and was it running in the background at the time? Yes, and it was probably not running in the background, but it could have been.
More background:
I believe my sequence of events was something close to the following:
9/18/26 I transferred to my iPhone 18 Pro and wiped the iPhone 16Pro..
Around 9/21/26 I went online with Roon ARC and downloaded some albums and then went offline.
Pretty certain I had quit the Roon app at this time.
I did some offline listening with Roon ARC with no issues during the remainder of September into mid-October.
During this time forward, Roon ARC was in the background when not playing music (app not quit).
On or around 10/26/26 I updated to iOS27.2; Roon ARC was still in the background, but not playing.
I did use CarPlay, but not the Roon ARC app.
I first noticed the issue sometime after this (not sure exactly when, probably around 10/30/26) and it persisted.
Not sure exactly when I updated to Roon ARC 1.85.439.
I quit and restarted Roon ARC a couple of times. It did not fix the problem.
Going online, signing in, and going offline with ARC then fixed the problem.
And ARC continues to work fine today.
I am sure there were other things going on, and my timeline is likely off a bit.
I seem to recall there was a CarPlay issue resolved in a recent update.
If I had to guess, something may have persisted even after the ARC update that cleared when I reconnected to the host.
Hope this helps
Hi @Inner_ear,
We’re going to leave verbose logs enabled for a few additional days for your account so reports will reach our servers automatically if you encounter the problem again.
If you don’t have any further battery problems the thread will close out automatically.
Thanks again for the update.
Hi @Inner_ear,
The latest diagnostics don’t show the telltale signs of iOS forcing the app to close due to thermal pressure, but we’re not able to ascertain everything from remote logs.
How has the app performed on 439 in the last few days?
If you’re not encountering any new problems, no need to respond. The thread will simply auto-close. You can reopen it anytime.
