Hi
I’ve got my Roon ROCK is running on an Intel NUC5i3RYH. It is connected to my router via Ethernet cable. I connected my NUC to my Atoll HD100 DAC via USB, nothing else is connected. There are 1598 tracks in my library.
The issue is that when I play a track, the sound coming from the DAC is terribly distorted and saturated. I already rebooted the Nuc few time, network too, the USB DAC too.
The issue is exactly what this OSMC user describes. I will try to install Arch and run Roon Server instead of Rock when I’ll have free time. Thanks for your help !
And if doesn’t work, I’ll use my Spdif usb interface which works well with Roon.
Bill_Janssen
(Wigwam wool socks now on asymmetrical isolation feet!)
8
I don’t know about that. The HD100 is not a USB-powered DAC (like a DragonFly). The power line on the USB port should not affect its operation. I’d check the USB cable, first. Try a different cable. Thinking about it, I bet that’s what happened when the OSMC guy added the powered hub – he used a different cable.
So, I found the solution. In fact, the Atoll HD100 itself is not usb powered, but the board that handles USB connection is. I forgot to mention that I’ve installed my NUC in a fanless case, which was shipped with a bigger power supply than the original. I finally tried with this power supply and the issue is gone. So it seems that the factory power supply of the NUC was just too weak to power asked by the Atoll USB
Bill_Janssen
10
Really? Wow, intriguing design decision.
Apparently the power capability of the NUC USB ports varies all over:
Yes, when USB is connected to a computer a green LED lights up on a board, and that whether it is powered or not, even if it’s not connected to main. intriguing design indeed.
