RoonOnNAS Beta for Synology DS v7.x running from SSD in Synology DiskStation 420+, 4-core 2.9GHz Intel J4025 Celeron processor with 10Gb DDR4 RAM
UniFi Gigabit Ethernet Switch and 2 x UniFi NanoHD APs
About half of my audio devices are cabled, with the other half using wifi
I run S2 for the majority of devices, and have a separate S1 system that runs my only incompatible S2 device. The old ZP100.
S2 Sonos System
Sonos One: Bedroom
Sonos OS: S2
Version: 13.3 (build 65121040)
Hardware Version: 1.26.1.7-2.2
Series ID: A201
IP Address: 192.168.2.147
WM: 0
Play:1: Bertie
Sonos OS: S2
Hardware Version: 1.8.3.7-2.0
Series ID: A101
IP Address: 192.168.2.123
WM: 0
OTP:
Play:5: Bungalow
Sonos OS: S2
Hardware Version: 1.13.1.7-2.2
Series ID: C100
IP Address: 192.168.2.156
WM: 0
Play:3: Kitchen
Sonos OS: S2
Hardware Version: 1.8.1.2-2.0
Series ID: A100
IP Address: 192.168.2.145
WM: 0
OTP:
Connect: Lounge HiFi
Sonos OS: S2
Hardware Version: 1.22.1.5-2.1
Series ID: D100
IP Address: 192.168.2.146
WM: 0
Port: Office
Sonos OS: S2
Hardware Version: 1.29.1.7-2.2
Series ID: A100
IP Address: 192.168.2.138
WM: 0
S1 Sonos System
ZP100: ZP100
Sonos OS: S1
Version: 11.2.12 (build 57821220)
Hardware Version: 1.1.3.2-2.0
IP Address: 192.168.2.144
WM: 1
20,000
- All 7 Sonos devices (6 x S2, 1 x S1) devices can be streamed to successfully, using any supported protocol (some have Airplay, others only support Sonos Streaming)
- All 6 Sonos S2 devices can be grouped together successfully
- All 3 Sonos S2 devices with Airplay can be grouped successfully
- When trying to add S1 device to any Sonos Streaming group, playback fails, and I get “Roon lost control of the audio device” error message, and no playback.
- Sometimes, the grouping appears to be successful (e.g. the S1 device is added to the group) but when I try to play, I get the same error message, and there is no playback to any device in the group.
I spent a couple hours digging around and haven’t found a straight answer to this. Some people report perfect grouping with S1 and S2 devices. I’ve tried factory resetting the ZP100 and creating a new S1 System. Same result.
I won’t be too disappointed if this isn’t fixable. Appreciate the ZP100 is a 15 year old network device. But if there’s a way to get it to work, I’ll be delighted, as it will save me retiring and replacing the amp for some outdoor speakers.
Thanks in advance for any help you can offer!
