Fairly regular skips in audio
Hi all,
Roon transmitting music to my Sonos One SL consistently skips audio. It doesn’t stop the audio, but just skips a second at a time. Are there any troubleshooting steps I can do myself, beside resetting devices and network? Which I have done
Specs:
Mac mini 2012
OS 10.13.4
2.5ghz i5/16gb ram/SSD
Latest Roon
Sonos One SL
Asus RT-AX86U
Hey @bluhska,
How is the SL connected, over Ethernet or WiFi? If on WiFi, I would try to connect via Ethernet as a test.
If you try to send the audio stream from Roon to an Apple device and then have the Apple device further streaming via System Output to Sonos Airplay, does the same issue occur?
2 posts were split to a new topic: Roon + Sonos Airplay issues
