I have a nucleus plus and I have a super 3 Farad power supply. I am told that I can use the farad with a nucleus but not with a nucleus plus. farad is 19 volt 3amp 80 watts. someone try it with a nucleus plus?
The Intel 7i7DNx NUC that the plus is based on requires a 19V 65W power supply, according to Intel’s website.
Roon’s store also says both nucleus and nucleus plus come with 19V 65W supplies
The roon site also both quotes a 3.42A spec (which is 65/19 as you’d expect)
So 3A is a bit low, although not quite sure how the Farads can quote 80W and only be able to supply 3A at 19V.
I have just contacted Farad and he will confirm the answer to me shortly. I’ll keep you updated
it seems according to farad that there is no problem to connect with the nucleus +
I,m very happy
