Core: MAC mini (6 months old) , OS 10.15.4
Remote: iMAC (end 2013), OS 10.15.4
WLAN
Many
Fault occurs after updating OS to 10.15.4.
Roon runs on MAC mini (core) and iMAC (Remote).
I use iMAC to listen to music.
Roon starts without problems on iMAC. Connection with Roon on core is stable. BUT: On iMAC I see fault message: “No audio device is found”.
Then I open start-window on MAC mini (MAC mini is running all the time) and suddenly the fault message in iMAC is deleted by itself and the Audio devices are listed.
No. 1 shows ROON , Tidal, on iMAC (Remote), directly after start. At the bottom you see “No Audio Devices Found”.
No. 2 shows ROON, main window, on iMAC (Remote), directly after start. At the bottom you see “No Audio Devices Found”.
No. 3 shows that I open a window to use the Mac mini, the window of the iMAC is in background. I do not need to log in the MAC mini. At the bottom, right hand, of the iMAC you see the Audio Device “Teufel Cinebar One”. That occurs in the moment, I open the Mac mini window.
No. 4 shows the iMAC window and everything is fine.
The only change I make is the Update of OS on iMAC and Mac mini. Nothing else. All the hardware is the same since months.
Same issue happens on iPhone or iPad by using the Roon App.
I start Roon App on iPhone/iPad. Roon starts, but no Audio Devices were found. Then I open login window of my core device (Mac mini) on my remote device iMAC and suddenly my iPhone/iPad shows the Audio Devices in the Roon App. I do nor need to login in the iMac neither in Roon (on core=Mac mini).
I think the next step here is to enable some diagnostics on your account so our technical staff can get some more insight into what’s going on here.
To give my system a new chance I switch it totally of first. But issue is still there. Here the time schedule.
My Time is Central European Summertime. Means 18:30 in Germany is 12:30 a.m. in New York.
The mentioned issue starts at 19:02.
18:30 switch off Mac mini (core)
18: 30 switch off iMac (remote)
18:33 switch on Mac mini
18:33 switch on iMac
18:35 login iMac
18:36 start Roon on iMac
18:36 Roon on iMac shows message „Remote connection waiting for remote core“. Remark: that is normal after a hard reset. System cant find core automatically.
18:38 open Mac mini window on iMac. Login on Mac mini.
18:39 Open Roon on Mac mini.
18:40 lunch time, wife is waiting.
19:02 Open Roon on iMac
19:02 iMac shows „No Audio Devices Found“.
19:03 Open finder on iMac. Open window of Mac mini. -> Roon is still oben on Mac mini
19:05 Close window of Mac mini
19:05 Roon is still open on iMac. Roon shows all Audio devices.
Thanks! Now that I have the timestamps, diagnostics have been enabled on your account. The next time your Core is active a diagnostics report will automatically be generated and uploaded directly to our servers
I just started Roon. There was no trouble. I rebooted my iMac to produce the trouble. But again, Roon runs absolutely fine. Maybe you have chance something already?
after several test over the last 2 days I can say that ROON works fine again. No more trouble anymore. I do not know, what you have done. But what I do know is, that solved the problem.
