Files with less than 16-bit density not playing (ref#CV7GFC)
· Ethernet
· The issue *only affects one file *format.
Which format is giving you trouble?
· Connected directly to my RoonServer machine
· Yes, it shows up there, but it isn't Enabled
Does the "Enable" button unlock the Zone?
· I pressed Enable, but the Zone remains disabled
· Only one output type is affected while the other output type works as expected
· the problem files are AAC44.1,257kbps all others are fine
· Once again not an issue
The issue only involves files with less than 16 bit density
no problems
Does this mean that you confirmed that other AAC files work, just specific AAC files don’t work?
Or is it simply AAC generally not working? In this case, what is your Roon Server running on?
Yes that sounds plausible. Roon will also not play 18- or 20-bit files. I think it is save to assume that Roon can only play 1-bit (DSD), 16-bit, 24-bit and 32-bit integer PCM files and, to be on the save side here, that are stereo (2-channel) at least – please don’t try to play real mono files.
And there is the not so helpful (because it misses the exceptions I listed) guide from Roon Labs:
Disclaimer: What I wrote above may contain traces of sarcasm.
Hey @Dr_Dave_Barr,
Thanks for writing in and sharing your report, sorry to hear about your file issues. We’ll need to sync with the internal team to discuss this further, but in the meantime, can you please upload a handful of your problematic files for our team to examine? You can upload them below:
Thank you! :pray:
