Typically the issue arises when starting a new album. Only the first track, No issues with following tracks of same album
Issue arises independently from track resolution. Occurs when skipping to same as well as to other resolution.
Unsure I understand what you mean with standard conformity. I am using Audioquest Audiophile Cat 7 Vodka cables which I must assume comply with the standard.
Thanks, so not related to resolution then. This happens, so is good to rule out.
Did this always happen for you or is it a new issue? (You might not be able to tell if new to Roon, but then at least we know that you can’t confirm that it worked perviously)
I’ve seen technical tear-downs of AQ Ethernet cables showing questionable compliance. Can’t be bothered to look them up. If it was standards-compliant, it would just be an Ethernet cable, no need to be audiophile whatever that’s supposed to mean in am Ethernet cable.
Anyway, even if you had bog standard cables, I would give the same advice: Try other ones just to rule out that there’s something wrong with one of your cables.
Definitely agree on the ethernet cable. I’ve read a number of posts from users who’ve resolved problems going from a cat 7 to cat 6. Just a basic cable will do.
