Google Pixel 6 Android (Wifi)
Roon Bridge Linux (Ethernet)
5000
Why does Roon need to do double bit depth conversion (16->64->24) when there is no DSP or volume leveling in the path ? This is on my Pixel 6 with Android L, outputting to either phone speakers or Bluetooth headphones (B&O H95)
It doesnāt only convert the bit depth, but also resamples from 44.1 to 48 kHz. All resampling is done in 64 bit. This resampling is by no means ideal, but thatās how it is on Android.
I donāt use Android, but my understanding is that the ānativeā sample rate of most Android devices is 48 kHz, and all content gets resampled to this.
Thereās tons of info on this you can look up with Google. But anyway, that answers your original question.
Thanks for the info, Iāll do more digging into Android.
I now understand that resampling to 48kHz is needed on Android but it doesnāt answer my original question of why Roon does bit depth conversion twice.
In order for the computations done during sample rate conversions not to introduce significant errors, you need either 32 or 64 bits samples. Roon uses 64 bits. Converting from 16-bit to 64-bit samples is lossless. Also, converting from 64 to 24 will not introduce more than around -144dB noise. Thus, bit depth conversions themselves are not doing any damage to the signal.
