Frequent connectivity issues with Roon and audio devices after updates (ref#463JIO)
Is your RoonServer machine running MacOS 15 Sequoia or above?
· I still can't see my endpoints as available Zones.
· I have a *mesh network* with devices connected to multiples points
Your local network might need some re-arranging to support Roon.
· None of the suggestions have helped me. I'd like to submit a support request.
· this week - last 72 hours
· as above
Update of any software/hardware in the system-chain causes Roon to stop communicating
System:
MacBook Air(Sequoia 15.1.1) serves as core
Sonos v 16.5.1 controls most of speakers
NAD M50.2
Tidal subscription
EERO 6.51.2 (2)
several times a month, whenever any hardware/software vendor updates the chain gets broken and Roon will not connect with speakers/Sonos. Sonos and NAD will continue to run the audio/system just without Roon connection. BluOS will allow the NAD to talk to its audio-output just not with Roon-connection. Only solution todate has been to reboot every element in the chain. Only takes about 30 minutes……. about 50% of the time that works. Otherwise I wait about 2 weeks and something in the chain gets updated and I get a pleasant surprise that Roon is now working. I have also tried making my wifi discoverable, but doesn’t seem to have any impact.
Roon continues to provide enjoyment, but the frustration is getting to point where having to consider whether to continue subscription.
Have considered Roon nucleus if it would resolve everything. However, don’t want to spend the $$ to now have another element in the chain that creates further complexity/failure/frustration.
Appreciate any wise counsel……….
as above - in addition the EERO has the base and four extenders.
Hi @Patrick_Rankin,
Thanks for reaching out to us about this issue. I think we will need to do a deeper investigation to troubleshoot this. We want to compare logging between when your system is in a working state and when it is in a non-working state. So can you please provide us with a date and time when everything is working and a date and time when it isn’t working to allow us to compare?
I don’t think that buying a Nucleus is likely to solve the issue. So my advice would be to hold off on that purchase for now.
Daniel,
Thanks. It is not working today (even to system output). I’m pretty sure it was working last Monday…
Thanks…
Daniel,
Quick update. It started working today. I had restarted my computer earlier in the day. Then after the Roon update today it stopped working. However, with restarting just the computer things are fine again. I can certainly live with just restarting the computer and not every piece of equipment in the network-chain. …
Thoughts? and thanks…
Hi @Patrick_Rankin,
I’m glad you were able to find a workaround for now that is not too burdensome.
I will create a ticket with our development team to investigate your logs from these periods and let you know what they tell us.
Hi @Patrick_Rankin,
Our developers have a few things they’d like you to try. First we want to try to rule out mDNS and multicast as root causes of this.
  1. Restart some Sonos devices and see if they disappear. Try again if they don’t. If they do disappear, then we will need to investigate DHCP servers, as there is something changing IP addresses of these endpoints.
  2. Set one Sonos Zone to a fixed IP and see if that works.
  3. Try to play to system output on a phone using Roon remote, which will not be relying on mDNS. If this fails, we can rule out mDNS.
Daniel.
  1. restarting devices and the did not disappear. Continued to work fine.
  2. changing to a fixed IP - not quite sure how.
  3. system output using the Roon remote works well.
Hi @Patrick_Rankin,
This forum post talks about how to set a fixed IP address for your Sonos devices.
