Mytek Brooklyn Bridge connected through Ethernet
Used for Tidal only, no local stored music
Been nonstop problems streaming Tidal through the Brooklyn Bridge. Most of the time the Brooklyn Bridge won’t show up in my Audio Zones and when it does it plays the first few seconds of a track before skipping or dropping off completely. Roon gives me an error message “Tidal media is loading slowly. This may indicate a network or connectivity problem.”
After scanning the message boards here I’ve tried these solutions to no avail:
Restarting, reinstalling Roon Server
Emptying Roon Cache
Using Static IP with Google DNS
Removing the network switch and powerline from the process
Using Mytek’s WiFi instead of ethernet
Nothing has worked. It’s incredibly frustrating after investing a lot of cash into this setup. Would love your help.
Welcome to the forum and thanks for reaching out, we can certainly take a look over these issues. Let’s start troubleshooting with the following:
What is your internet download/upload speed according to speedtest.net?
Do other zones work as expected? If you try outputting to the ROCK’s HDMI zone or to a Roon Remote’s (Android/iOS) internal speakers, do you have TIDAL playback issues there?
Are you using the latest firmware on the Mytek?
Does this issue only occur on certain types of TIDAL content, such as it only occurs when trying to play back MQA or content over 44.1kHz?
Thanks for confirming. Can I please ask that you reproduce this issue on the Brooklyn Bridge and note the exact local time + date + track the issue next occurs on? Once I have this info I can enable diagnostics mode for your Core to see if we can get more clues in the logs.
For the first few hours of streaming today it worked perfectly. Was able to listen to 3 Miles Davis Albums without hiccups. Then at 7:12 PM PST on May 18, I tried to listen to the album Discoveryby Daft Punk and every track skipped after 6 secs or less
Thanks for letting me know that timestamp. I have gone ahead and enabled diagnostics mode for your account and what this action will do is next time your Core is active, a set of logs will automatically be generated and uploaded to our servers for analysis.
I can confirm that this report has been received and I have requested additional feedback from the technical team regarding your case, once I hear back from them with further information, we will reach out once more, thanks!
We apologize for the delay in getting back to you, the diagnostic logs showed some odd behavior and the support team wanted to clear things by the QA team before responding.
It appears that the issue during streaming is occurring on the Brooklyn Bridge network module, your Roon Core appears to be operating normally.
What we see in the logs is that the Brooklyn Bridge is reporting “Dropout” traces which means that it is unable to fill the audio buffer with data fast enough to keep up with playback:
I recommend reaching out to the Mytek support team with this information and continuing troubleshooting with them. I would be interested to see if you’re able to stream without issue using the MConnect application on a smartphone. Based on the troubleshooting you’ve already performed, I would think that the network is not the issue here.
Thanks John and team for following this to the end and giving me confirmation that it’s not my network. I’ve taken the issue up with Mytek and have sent the Brooklyn Bridge in for repair. I’ve cancelled my Roon account as to not incur charges until I know I have a network bridge that works. Hope to come back to Roon when it does.
