This is a great accessory for improving digital audio sound quality. It has multiple features and use cases:
- passing audio from a PC via USB and outputting it in spdif (optical/coaxial/bnc/aes) for input into a DAC
- re-clocking spdif signals to reduce jitter
- converting spdif audio to USB audio e.g. for recording on a PC or for a DAC that only has a USB input
The latest firmware is installed - sounds better than ever.
No original box, but it will be well packed.
£500 incl delivery. UK only sale, sorry
Reviews:
http://hifipig.com/mutec-mc-3-smart-clock-usb-master-clockreclockerspdif-converter/
Here is the official manufacturer’s product page: https://www.mutec-net.com/product_mc-3-plus-usb.php
"The MC-3+ Smart Clock USB is setting a new benchmark for clocking technology and the reproduction of digital audio by uniquely combining an audiophile USB interface with an audio re-clocker in perfection! Particularly designed for the demands of high-end consumer audio, the device expands a new sonic universe with increased musicality, clarity, and precision. As such, the MC-3+USB will prove its worth in many audiophile listening rooms around the world.
Unique, bit-transparent Re-Clocking without conventional sample rate conversion for purest sound quality
Audiophile, asynchronous two-channel USB interface with ultra-low noise audio clock oscillators and total galvanic isolation of up to 2500 VRMS, respectively 4242 VPK, for suppression of high-frequency interferences
Converts DSD/DoP streams (64-256) to PCM audio with selectable output clock rate
Locks to MUTEC’s REF10, as well as so-called atomic clocks and GPS clock references
Improved, next-generation REVIVE re-clocking and 1G-Clock technology by MUTEC
Additional Features:
Serves as a flexible digital input switching matrix, audio format converter and master clock
Compatible to Apple Macintosh and Windows PCs
Intuitive user interface and easy installation
Update-capability via USB
Available with black- or clear aluminum front panel
Galvanic isolation up to 2500 VRMS in accordance with UL1577, respectively 4242 VPK in accordance with DIN EN 60747-5-2 (VDE 0884 part 2)
Transfers USB audio streams into AES3 and S/P-DIF and outputs those to five digital audio formats simultaneously
Converts between USB PCM audio, USB DSD/DoP audio, AES3 and S/P-DIF, as well as between AES11 and Word Clock
Highly compatible USB audio class 2.0 driver for Windows supporting ASIO, MME, DirectSound, WASAPI, Kernel Streaming, PCM 16Bit, 24Bit, 32Bit and Float-32Bit at all clock rates between 44.1kHzand 192.0kHz
Ultra-low jitter Word Clock generation with clock rates up to 1,536.0 kHz
Scalable to FS1x512 clock rates, 22,5792 MHz & 24,576 MHz, for e.g. high-end audio interfaces
Locks to Rubidium- (10 MHz), Cesium- (5 MHz) and GPS clock references
Generates Word Clocks, Super Clocks, AES3 + S/P-DIF blanks simultaneously
Uninterruptable, fail-safe clock generation in all operation modes
Eliminates so-called digital “clicks and pops”
Individual lock indicators for the clock or audio reference and the re-clock reference
USB, AES/EBU, AES/EBUid and S/P-DIF interfaces in one box
S/P-DIF interconnections via BNC, RCA and optical interfaces available as in- and outputs
Front panel lock-out for preventing of misuse
Rack-space-saving 9.5" housing
Built-in, universal power supply
