For sale here is my UpTone Audio JS-2 Linear Power Supply. If you know this supply then you know how great it is. I am currently using it to power my Mytek Brooklyn DAC+. It made a huge improvement over using the internal supply on the Brooklyn DAC+. When I bought it I also purchased the extra DC CABLE (JS-2 output jacks are 5.5mm x 2.5mm) so it will come with two cables. I have only owned this PS since August so it’s less than a year old and in mint condition. I have the original shipping box and will pack it securely. I am asking $750 for the power supply plus $25 for shipping. USA ONLY please.
This from the UpTone Audio Web site:
Dual-output, choke-filtered linear power supply with four user-selectable DC output voltages.
Two independently adjustable, separately regulated outputs; Voltage choices are user set from the back panel: 5V, 7V, 9V, or 12V.
Guaranteed current capability is 5 amps continuous from either output at any voltage setting.
(Up to 7.0 amps split between outputs, depending upon DC voltage combination; Instantaneous capability of up to 10A).
User configurable for worldwide operation at 100/120/220/230/240 volts AC.
Dimensions: 9.0 inches wide x 9.1 inches deep x 3.3 inches tall (with feet).
Weight: 10.5 pounds; 14 pounds in its full double-box shipping cartons (shipping dimensions 14"x14"x9").
