Thank you for the heads up on this. I just checked the page you linked and the images are working for me on Chrome. Can you try using a private tab or another browser and see if that helps?
I am looking for the page which caused me the problem and I can’t seem to locate it. I checked the link in my original message and it seems to be working??? I don’t know what happed or if I did something wrong. At any rate I figured out a method to to use Genre and software to help me correct the tags to get it to work correctly. If I happen to find the page, I will update you then. Thanks for the reply.
