Cheers. What PSU are you using with your Rendu?
Thanks gentsā¦but iām trying to visualise the attachment of the MR to the kefs ā¦any pics pleaseā¦as obviously itās different from the desktop setup with lps powersupply etc.
thanks
Teddy Pardo power supply
Today, I added a Kef Kube 10b subwoofer to my LS50W. Easy add on and not much tuning testing required. Just set it to LFE and vol set to default level. And, turn on subwoofer on Kef Control app. Thatās it. And, the music is SWeeeet. Only regret is not have added one much earlier.
I strongly recommend all LS50W owners to add a subwoofer.
II agreeā¦ a quality sub with monitors makes so much difference.
a good sub takes the hard work off of their hands, too, for the bottom end.
I got the white SVS SB 2000 to match the white kefs i haveā¦
a few wall pads might be nextā¦but weāll see.
iāve had the SVS āsalmon smokerā tall tubular sub beforeā¦they
make solid, great bang for buck products.
