If stick with the Topping myself unless your going up a considerable amount.
You’re going to have a nice little rig.
I need to sit about 10 feet from the hardware and I like to fiddle with volume. I either need something with a decent remote or something that can act as a decent Roon (preferably RAAT) zone with a controllable device volume.
Something from Project or Matrix would work but I’m just dabbling here and prefer the Schiit price point. Need to do some more research
I’d suggest, in my case If I were to sit that far away.
RoPieee > Topping E30 (remote volume) > Magni 3
I’d look to set RoPieee to fixed volume within Roon, and the Magni 3 volume a little high and attenuate volume with the E30, just won’t go to low in volume on the E30 in case of ‘bit stripping’.
I did not know the E30 had remove volume. Thanks for the pointer! That may be exactly what I do.
Awesome! Hope you love it!
It sounds much more punchier than I had expected. Sounds very good.
I had the Pro-Ject Pre Box S2 Digital, which I found be to very pleasant sounding but a bit underpowered for several of my high impedance full sized headphones. On easier to drive headphones the Pro-Ject Pre Box S2 Digital works and sounds very good.
My headphones are not that high impedance, thus I am quite happy with the Pro-Ject. I really like the little box a lot.
But the headphone topic is still quite new to me, which is why I will certainly make changes to the setup here and there in the future.
I switched from Schiit to Topping. Passed it along to my son.
Been having the Topping E50 DAC for a little while and just received the matching L50 headphone amp this week.
Like most, I keep tweaking here and there and every once in awhile a tweak is made and you feel that this tweak was very noticeable and impressible. That was this amp for me.
–MD
