Help!!! Was working fine for weeks, now getting bumped off constatnly;. HELP!!!
Had a similar problem recently. Fixed it by removing the HQPlayer endpoint from Roon (Settings>Audio) and then re-enabling HQPlayer (Settings>Setup) using the IP address of the HQPlayer server. This requires having a fixed IP for the HQPlayer server, which I can do easily with a setting on my router.
