Help - Endpoint device disappear and reappear
iMac - hard wired to modem with ethernet
Actiontec MI424WR
Sonnet Hermes with Ethernet connection hard wired to modem
I have an endpoint device (Sonnet Hermes) that keeps disconnecting and disappearing and then reappearing sporadically. It starts with the audio of the song dropping out, then the device disappears all together, and it takes a minute or two for it to come back, and then I have to hit play again. This happens randomly. Any info would be greatly appreciated.
Hi Wes, welcome to the forum.
Generic suggestion, but make sure the firmware is up to date and restart the player and Roon Core. I had a Bryston BDP-1 that used to play hide and seek with me. It ended up being a flakey ethernet cable.
Also, is the problem with music files, or limited to use with Tidal/Qobuz. The streaming services need to be logging into once in awhile too.
#support
Hey there,
I recognize you from headphones.com forum, and it is nice to know you are here to. Thanks for the info, and I will try all that, when I get home from work. I will get back with you, once I have tried all that.
Thanks,
Wes
Hey Robert,
Just checking back in to say thanks! The simple restart of everything, and I am up and running without issue.
Back to continuous music. :grinning:
Thanks,
Wes
Awesome, glad you’re back in service… :grinning:
