Check that firewall is not filtering out the necessary multicast packets. It is also useful to check that there are no other audio applications running that would keep the audio device reserved…
Hello Luis,
I have very similar set up:
Mac Mini i7 16gb ssd with shared ethernet via LAN to mRendu NAA to dCS Debussy dac.
Running Roon to NAA via shared ethernet is no problem.
When Roon / HQ Player to NAA is on, HQ Player can’t see mRendu in HQP preferences under Network Adapter.
Can anyone HELP,
PLEASE
ps
I send email to Jussi long time ago but never got response.
I hope he will read these post
Hello Jussi,
My system is Mac Mini i7 3ghz with 16mb / Roon / mRendu or sms 200 / dCS Debby dac.
I’m sharing the Internet from the Mac Mini to the mRendu via ethernet connection from the Mac Mini port.
All works well in these configuration.
When I start HQ Player in the same configuration us above, HQP can’t find the mRendu in the drop down menu under preference / NAA adaptor / …
That is the problem I have.
I hope you can help Jussi.
Thank you in advance for your time,
VP
Can you describe what do you have on the way from Mac Mini to the microRendu? Understanding the setup/topology may help figuring out where something could go wrong…
Hi
I am using NAA on a MacBook. When i close the MacBook, it switch into StandBy, what is good.
But, wenn i reopen it, NAA is not responding anymore.
Is there a way, to close NAA and reopen it by a script? When i close the terminal window, it seems, that the Ports from NAA are still blocked and i need to reboot the MacBook.
