My NUC arrived by mail today. Now I am busy installing ROCK on my NUC5I3RYK. I followed all the steps in the installation guide on the Roon site. However if I plugin my usb-stick containing ROCK and press f10, select the USB-stick, the screen becomes black and now signal is there. I tried it over and over, resetting BIOS etc… I don’t know what to now…
sandisk should be ok. It is possible there is a corrupt image from roon side…I think that happened once before, but the support guys will chime in shortly no doubt.
its been a while since I installed ROCK…over a year at least so I am a bit rusty on the process and files etc but if you are following the KB docs it should be pretty well documented here https://kb.roonlabs.com/ROCK_Install_Guide
I would open up and refit the M.2 card again. sometimes the contacts can oxidise and a couple of plugging in and out will wipe them sufficiently to get things working.
A list of the components you are using would be good along with a link to the ROCK image you downloaded. What else is plugged in?
I installed ROCK for the first time before Christmas and the after enabling legacy boot and putting the USB stick in a front socket it all worked perfectly.
Could it be something daft and the blank screen be an monitor issue? Unsupported resolution?
